Diesel Forum - TheDieselStop.com - View Single Post - 99 F350 SD 4x4 - MANUAL FRONT HUB REMOVAL...
Old 11-09-2008, 01:03 PM   #1 (permalink)
cmb1998
99 Ford F350 4x4 with Manual front hubs. I am trying to get the front hubs off my truck to greese them (very hard to turn) and I can't seam to get them off. Wanted to see if there was a trick or somting.
The Chiltons manual I have says to remove the tire...front caliper & disk... then the clip retaining the hubs and then it shows thehub just poping out.
I did above and can't seam to get the hub off (don't see why though, do you really need to remove the wheel and all?). remove the retaining clip and pull on the hub and it won't budge...
Thanks for any help!
Chris
cmb1998 is offline   Reply With Quote
