I have been experimenting with HHO. built units with wire spirals mounted on persplex frame.
Fitted to independant persons vehicle for testes.He was a nayer.
Six diesel tank s full three with and three without over 3,000 Km and his assesment was approx 10 % saving.
Downside the wire was eaten away. But he still wants a unit.
Now building up a tube in a tube unit bigger and more surface area.
We will soon have the results of this unit.
Have a wire unit fitted to the "F" and also a Ford trader truck on 2/1 mix diesel and WMO.
No figures on these units as not suitable usage for recording.
The old nayer you dont get anything for nothing is right
But if you use x units of power to produce xx units of power adding the power of hydrogen you get a net increase.
More experimenting required when time allows.
Regards
Ron
2000 F350 king cab 4x4,No engine mods,Roo Bar,Headlight and bonnet stone protectors,Inlet snorkel,flares on front,Engine driven air compressor and receiver,Hot water tap,tyre temp and pressure monitor,95 ltr fuel tank under right hand side,aluninium side steps,flat trayback,50ltr water tank under left hand side,heavy wired front and back for 4500lb electric winch, Bilnstien shocks,converted to right hand drive,battery conditioner,electric trailer brakes,heavy duty tow bar,synthetic oil in tranny,extra tranny coolerand filter ,tranny temp & pyro,
Ride-Rite airbags all round.Full flow muffler outlet at rear of vehicle.Engine breather mod.HHO generator
