Diesel Forum - TheDieselStop.com - View Single Post - air ride kit
Thread: air ride kit
Old 11-12-2008, 10:23 AM   #11 (permalink)
drford
Originally Posted by Jcart View Post
Djanzen....that is the one I was thinking of and drford if you look at the installation guide (pdf. file) in the link you can see how it works. One question with this system, how do the links account for different axle to link angles?. Imagine driving on uneven ground, the passenger side wheel travel up say 6 inches and the driver's side remains on level ground, there will be a binding action at the interface on the axle perches, links and u-bolts. I could see if the front link to frame was a hiem joint, this would provide for what I'm getting at but the pix don't indicate that. I think this an interesting suspension, easy to install, minimizes axle wrap and I would guess smoother than stock and adjustable ride height. Interesting to see if anyone has put one on a 4X4.
jrc
i tried googling them no luck do you have a link to their website ?? thanks
1996 F350 2WD DRW CC Black STG1 160 CC INJECTORS , D66 TURBO FROM BEANS ,3.5" DOWN PIPE 4" MAGNAFLOW EXHAUST, SD HPOP , CPR FUEL SYSTEM ,DIY TYMAR AIR FILTER , DP TUNER WITH F5 , AUTOMETER GAUGES PYRO - BOOST - TRANS TEMP - COOLANT , DIPRICOL HPOP GAUGE .
6.0l SD INTERCOOLER MOD WITH NEW CUSTOM MODDED TANKS AND AEM WATER METH KIT TO HELP LOWER EGT'S ON HILLS , E40D HIGHLY MODDED
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2007 SPORTSMAN 500HO STEALTH BLACK
2008 SPORTSMAN 800HO STEALTH BLACK
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline   Reply With Quote
