I was running B100 in my truck. I only put the Bio in the Aux tank, and let it fill up the main tank. I knew that the Bio would clean out the system after the first couple of tanks, so I replaced the filters after 500 miles; they were pretty dirty looking!
I have a small filter between the aux tank and the main tank. After about 10k miles, the small filter clogged up and I needed the fuel from the aux, so I removed the filter.
About 150 miles later, the stock filters completely clogged! The truck wouldn't go over 35 MPH. I replaced the filters (AND the small filter for the aux tank) and everything worked fine again.
I buy the Bio from a large truck-stop fuel dealer near me. He moves large amounts of the BIo, and has all the regular filters at the pumps.
So, I think the problem has to do with filtering.
I don't think that any of the major Bio producers filter to a small enough micron level. I think this causes the 6.0's filters to clog up.
The little aux tank filter that I used was just enough to filter out the goo from the bio.
I LOVE running Bio Diesel, but I've had to cut back to B20 because of the clogged fuel filter problems.
SInce switching, I still see the aux tank filter cogging up, but it seems to last a lot longer.
I think the guys that make it themselves filter the Bio a lot better, so they never have any issue.
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
