Diesel Forum - TheDieselStop.com - View Single Post - Ball Joints
Thread: Ball Joints
Old 11-14-2008, 07:43 PM   #18 (permalink)
westvandude
westvandude's Avatar
On their homepage click on the "Powerstroke Specials" link and you'll see them listed second item down.
Powerstrokeshop.com
Man... installed new seals and a u-joint on driver's side axle shaft during the day today. What a pain in the arse. The c-clips were pretty hard to remove. Otherwise the u-joint went in ok.
The bearing seal was something else. Tried beating it on with a piece of pipe and the seal started deforming. Couldn't find cast iron pipe big enough to make up a tool using the pipe flange idea. Ended up putting together some much larger stuff from 1 1/2 or 1 3/4" cast pipe from autoparts store. That worked but lemme tell you, you have to pound on that thing with a BIG hammer to get it on and real easy to put it on slightly offset. I couldn't believe the amount of pounding it took to seat it properly. The smaller axle side dust seal went on real easy in comparison.
2001 F250 4x4 crew lariat 7.3L auto, DP Tuner F5 no-start/valet/20tow/80econo/140aggressive, Adrian Tavano's triple disc converter, transgo tugger HD2, ISSPRO egt/boost/pyro, foil delete, 6" stainless tip, Magnaflow 17979 4" turbo-back, dieselsite boots & coolant filter kit, HX crossover, boost fooler & tru-cool trans cooler, ported turbo housing, DIY 6637 Tymar, billet grill, line-x bedliner, bug deflector, tint, 08' alum diff cover, clear corners & tails, silverstar bulbs, Xtreme XT855 reverse lights, 1500w inverter, Tekonsha Primus, EQX, Epicenter, Autotek MM4000.1D, 2x Audiobahn AWT12X, 2/0 cables, JVC KD-AVX44 El Kameleon dvd deck, 12.5" flipdown video.
2009 VW Jetta 2.0TDI 6spd Highline full load except nav. 19" Audi RS6 rims. Custom fiberglass hifonics 12" sub & 280w usacoustics amp. Tint is next.
westvandude is offline   Reply With Quote
