1) Ground your antenna - the cargo management system may or may not have a good ground to the body. You want to run your ground wire from the mount bracket on the antenna to a good body ground.
2) I would look for a taller antenna. 6 inches above the cab is not very much. Higher is better, closer to the center of the truck is better.
I have had good luck with the Francis antennas since I came across them 15 years or so ago.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, 286,000 miles, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, 36" tall ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
