Diesel Forum - TheDieselStop.com - View Single Post - CB Tuning Question - help!
Old 11-15-2008, 08:37 PM   #3 (permalink)
OT
OT's Avatar
Z71..maybe others will chime in cause I'm rusty..meantime JMO...
You need longer/swr adjustable antenna..2/3 should be above cab top. You can tune fglas BUT its tricky/time consuming & require's various parts.
Move mount to good metal contact. You might need diff. type depending on where you put it..ready made or make your on. I assume coax is ok & around 18' long for starters. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline   Reply With Quote
