Old 11-16-2008, 01:05 PM   #1 (permalink)
hutchinaugusta
hutchinaugusta's Avatar
1999 F250 Billet Grille Install
I just received a 4 piece billet grill for my truck, it came with no instructions. It is the one where you cut out the center of your grille. Do I grind/trim all the grey inside part of the grille to the edge where the chrome begins? Which way does the insert install? What about the side parts, do the tabs mount on top or bottom? Does anyone have photos of cut out flush billet grill install??
thanks.
99 F250 2WD LARIAT CREW CAB, 3.73,NMN1 REFLASH WITH "MILD" ASE MECHANIC PROGRAM (TOTALLY AWESOME) DIESEL POWER "ASE Mechanic TRANS-GO SHIFT KIT W/LATE MODEL SERVO PACK FROM BRIAN's, BILSTEIN, AIS AIR FILTER ASSEMBLY, PILLAR W/BOOST & PYRO, DUAL FUEL BY-PASS CIRCUITS W/AEROMOTIVE REGULATOR AND RESTRICTED RETURNS @ HEADS, "HUTCH MOD" FUEL SUPPLY AND TANK MODS, 2002 INNERCOOLER W/ENGINE BLOW-BY RE-ROUTED, OWNER FABRICATED 4" TURBO BACK EXHAUST WITH BIG RIG MUFFLER, Q-FORMS W/DYNAUDIO FT., FOCAL DRIVERS IN CUSTOM ENCLOSURES REAR, JL AUDIO STEALTH BOX, ADCOM & NAKAMICHI AMPS, CLARION PRO HEAD UNIT, LINE X BED LINER, ROLL N LOCK COVER, 01 LARIAT WHEELS, LED'S IN OVERHEAD CONSOLE, LIGHTS OVER RUNNING BOARDS & IN BED http://community.webshots.com/user/hutchinaugusta</span>
hutchinaugusta is offline   Reply With Quote
