Old 11-17-2008, 05:07 PM   #2 (permalink)
OMCUSNR
Originally Posted by markreigle View Post
Ok, so my water in fuel light comes on and I get around to draining it two days later. When I unscrew the plug I get about 6 ounces or so of liquid (I assume a mix of water and fuel).While I'm at it I change both fuel filters. I think this should take care of the light but after a few hours it comes back on. The next dayI drain it again and as before I get about 6-8 ounces of drainage.....hmmmm....light goes out. Whoa....next day, light is back on and I go through the same scenario all over again.
First off, should I be getting that much drainage? I don't remember getting that much on previous drains. Second, could it be that I just have a dirty sensor and if so is it is to clean? Right now the truck runs very rough at first start but after it warms up it seems to be just fine....maybe I got a tank of bad fuel ....
If I try to drain with more than half a tank, I can get a gallon or two out.
I didn't see in your post - do you actually have water in your fuel? Little bubbles on the bottom of the container? It is possible that your sensor has become corroded, and needs to be replaced.
OMC
OMCUSNR is offline   Reply With Quote
