I would check with the dealer and give them the vin # of the truck. There is also an online site you can check but I do not have it handy. They can check if cam sensor has been replaced. If it has a recall no charge. It usually is an intermittent problem and will start after sitting for a while. The other thing I would suggest is do a search for hard start/no start diagnostics. You should find a lot of information on this topic. Also, you may want to check the EGR valve. They are prone to getting clogged up on these trucks. I don't know if this would affect starting. Are you getting a check engine light? If it has been sitting at an auction for a while I would also charge up the batteries.
