Old 11-18-2008, 01:59 PM   #7 (permalink)
LOBOLOCO
Originally Posted by markreigle View Post
Where did you spray the carb cleaner in from, the drain plug hole or unscrew the filter and sray it in there?
Thru the drain plug hole. You just have to work aroud the front drive shaft the best you can. As was later stated, your sensor is probably OK since the light does go out, but I don't think you have anything to lose in cleaning out the sensor area. Just my dos pesos.
2003 6.0 6 speed. 3.73 gears, 4X4 w/Camper pkg. Ordered Oct 02, Received Mar 03. 100% stock.
LOBOLOCO is offline   Reply With Quote
