Diesel Forum - TheDieselStop.com - View Single Post - Whats it worth? 05 CC DRW on ebay
Old 11-18-2008, 06:30 PM   #3 (permalink)
27x10.5
Well decorated, but the major stuff has been taken care of I guess?
Standard Claims List For Model Year 2005
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 8 2E06 030008 5C4Z 9A543 A E23 D1 37500
AWS Claim Key: 3296414 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:07232951
Cust Comments: C S OVERHEAT WONT RESTART LEAKING FLUID
Tech Comments: LEAKING COOLANT PRESSURE TEST, INSPECT, REPLACED EGR COOLER AND HIGH PRESSURE PUMP, RETEST OK. WPI
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 8 2E06 030008 4C3Z 9E527 AA D42 28 37500
AWS Claim Key: 3524142 Trx Code: S07 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:17-JAN-2006 Doc #:07232952
Cust Comments: C S VEHICLE HAS A LOSS OF POWER
Tech Comments: NO POWER RD TEST, VERIFY, PERFORM DIESEL DIAG, RR 2 INJECTOR, RETEST, RD TEST, OK. WPI
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 9 * * * * * * * 44501
AWS Claim Key: 4121930 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2006 Doc #:07657241
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: RECALL 05B32 RECALL 05B32 DONE. WPI
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 9 1H03 030008 5C3Z 9F452 AA E29 41 44501
AWS Claim Key: 4121931 Trx Code: S07 Labor Hrs: 5.2
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2006 Doc #:07657252
Cust Comments: C S CHECK ENGINE LIGHT ON
Tech Comments: C S PERFORM DIESEL DIAG CODES P0404, P0299,R AND R EGR VALVE, CLEAR CODES, RETEST, RD TEST
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 9 2H01 030008 5C3Z 6K854 CA N12 01 44501
AWS Claim Key: 4121932 Trx Code: E72 Labor Hrs: 3.7
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2006 Doc #:07657253
Cust Comments: C S CHECK HISSING COMING FROM NGINE WHEN DRIVING LOSS OF POWER FROM TURBO
Tech Comments: HISSING NOISE REPLACE Y PIPE AT TURBO AND CAC TUBES, RD TEST, OK. WPI
AWS Claim Key: 4121929 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:13-MAR-2006 Doc #:07657240
Cust Comments: 05E16 ENGINE CONTROL MODULES RECALIBRATION
Tech Comments: RECALL 05E16 RECALL 05E16 PERFORMED
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 10 2E06 030008 4C3Z 9E527 AA D42 42 46605
AWS Claim Key: 4193635 Trx Code: S07 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 02292 - * Name: WEST GATE FORD TRUCK SLS INC Ph: 330-7934421 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:31-MAR-2006 Doc #:072820A
Cust Comments: BLOWING SMOKE HAS NO POWER, NOISE IN ENGINE
Tech Comments: 46605 (307)TOWED IN WILL NOT START ENGINE IS HYDROLOCKED AND BASE ENGINE OIL LEVEL IS OVER FULL. REMOVE VALVE COVER LEFT SIDE REMOVE ALL GLOW PLUGS BUMP ENIGNE OVER #2 CYCLINER FULL OF FUEL NEEDS INJECTOR DRAIN ALL OIL R&R OIL FILTER AND FILL WITH OIL ALSO REMOVE #2 INJECTOR FOUND HOLD DOWN BOLT LOOSE ONLY FINGER TIGHT LOWER O RING GONE AND FIRE WASHER NOT INSTALLED (307)CLEAN
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 11 1H03 030008 4C3Z 9P456 AC L87 D8 51475
AWS Claim Key: 4715345 Trx Code: S07 Labor Hrs: 6.3
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2006 Doc #:07966751
Cust Comments: C S COOLANT BLOWING OUT OF EXHAUST BLOWING WHITE SMOKE, TOWED IN
Tech Comments: COOLANT LEAK REPLACED EGR COOLER, M TIME FOR TESTING
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 12 1F05 030306 4C3Z 8A616 AA E23 42 58231
AWS Claim Key: 5018998 Trx Code: E72 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:08-JUN-2006 Doc #:07994303
Cust Comments: ENGINE FAN CLUTCH NOT WORKING
Tech Comments: RUN SELF TEST AND PIN POINT TEST PULL CODES AND TESTED AND REPLACED FAN CLUTCH AND RETEST OK.
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 13 1H03 030008 4C3Z 9P456 AC L87 42 62148
AWS Claim Key: 5247457 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:10-JUL-2006 Doc #:08061601
Cust Comments: LOSING WATER/COOLANT
Tech Comments: ROAD TEST AND VERIFY PRESSURE IN OVERFLOW TANK. OVERFLOW FROM TANK ON MOTOR AND HOOD. DIAGNOSED AND REPLACE EGR COOLER AND RETEST O K.
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 14 1A02 030102 4C3Z 6051 EA L87 D8 62739
AWS Claim Key: 5510099 Trx Code: E72 Labor Hrs: 15.1
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:18-JUL-2006 Doc #:08084101
Cust Comments: LOOSING WATER
Tech Comments: PRESSURE TEST COOLING SYSTEM. COMPRESSION TEST, DISASSEMBLE ENGINE AND FOUND RIGHT CYCLINDER GASKET LEAKING. REPLACE BOTH HEAD GASKETS. REPLACE CAM SENSOR LEAKING OIL. REPLACE RADIATOR CAP AND AIR FILTER SENSOR COOLANT DAMAGE. ROAD TEST RECHECK ENGINE AND COOLING SYSTEM OK.
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 17 2I04 NANANA YC3Z 12B533 AA D03 42 87134
AWS Claim Key: 6300850 Trx Code: S07 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:02-NOV-2006 Doc #:08328401
Cust Comments: RUNS ROUGH ON COLD START
Tech Comments: RUN IDS TEST AND PIN POINT TEST. PULL CODES CHECK EGR VALVE AND CLEAN AND RETEST.VALVE TEST OK.TEST FUEL PRESSURE.CHECK ALL GLOW PLUGS.CODE FOR # 2 GLOW PLUG.SWAP # 2 AN D # 4 GLOW PLUG. STILL SHOW # 2 GLOW PLUG FAULT.CHECK WIRING. REPLACE GLOW PLUG RELAY. ROAD TEST OK. COLD START OK.
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 18 1H03 030008 5C3Z 9F452 AA E29 55 89770
AWS Claim Key: 6491101 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:08368803
Cust Comments: CHECK ENGINE LIGHT COMES ON WHEN HAVE TRAILER
Tech Comments: ON AND 3 CARS, GOES BACK OFF WHEN DROP CARS OFF TRAILER BASICALLY ONLY COMING ON WHEN UNDER A HEAVY LOAD. PULL EEC CODES AND INSPECT AND REPLACE EGR VALVE PER TSB 06 19 06. RETEST OK.
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 18 2E03 030402 4C3Z 9E527 AA D13 42 89770
AWS Claim Key: 6491100 Trx Code: S07 Labor Hrs: 5.3
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:08368802
Cust Comments: COLD START PROBLEM STILL IF CYCLE GLOW PLUGS
Tech Comments: 3 4 TIMES WILL START OK, BUT STILL RUNS LITTLE ROUGH WHEN START DRIVING. RUNS GOOD AFTER WARMED UP. RUN EEC TEST AND PIN POINT TESTS.DIAGNOSED AN D REPLACED # 1 INJECTOR. RETEST AND CHECK OK.
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 18 2H01 031202 6C3Z 6C640 A L65 01 89770
AWS Claim Key: 6491102 Trx Code: E72 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:20-NOV-2006 Doc #:08368804
Cust Comments: CK OIL LEAK.
Tech Comments: INSPECT AND FOUND TURBO HOT AIR HOSE BROKEN. REPLACE AND RETESTOK
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 18 1B03 030204 3C3Z 6A642 AA L87 01 94219
AWS Claim Key: 6657473 Trx Code: E72 Labor Hrs: 9.7
Dlr Cd-Sub Cd: 00477 - * Name: DAVE KNAPP FORD L-M INC Ph: 937-5473000 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2006 Doc #:08415901
Cust Comments: COOLANT LEAK USING 1 GALLON COOLANT EVERY
Tech Comments: 200 MILES AT FIRST. THEN WHILE DRIVING DOWN ROAD, HEARD A LOUD POP NOISE, AFTER THAT THERE WAS SMOKECOMING OUT EXHAUST ALL THE TIME, COOLANT COMING O UT OF MOTOR AREA SOMEWHERE. DRIVER KEPT TEMP GAUGEOUT OF RED. PRESSURE TEST COOLING.BLOWING PRESSUR E INTO OVERFLOW BOTTLE. REMOVE INTAKE,EGR COOLER HAS LARGE LEAK.CALL TECH HOTLINE ID 308585883 REMOVE OIL FILTER AND INSPECT STAND PIPE FOR DAMAGE OR
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 28 6Y20 000001 * MISC * A98 82 97648
AWS Claim Key: 8767919 Trx Code: P01 Labor Hrs: 0
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2007 Doc #:01941454
Cust Comments: C/S REFUND FOR VEHICLE PAYMENT
Tech Comments: C/S REFUND FOR PAYMENT WHILE VEHICLE WAS IN FOR REPAIR
1FTWW33P15EC50232 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 23-FEB-2005 21-JUN-2005 113058 USA 28 2E03 030402 4C3Z 9E527 AA D42 42 97648
AWS Claim Key: 8726379 Trx Code: S07 Labor Hrs: 4.4
Dlr Cd-Sub Cd: 03604 - * Name: OASIS FORD Ph: 732-5911111 St:NJ Ctry Cd: USA Reg Cd: NA Repr Date:24-SEP-2007 Doc #:01941452
Cust Comments: CUSTOMER STATES BLOWING SMOKE BLACK SMOKE
Tech Comments: BLOWS SMOKE BATTERY TEST, CHARGE, AND RE TEST
27x10.5 is offline   Reply With Quote
