I agree also, run run run. Just pretend you never even found this truck because it will be a money pit. Also I cut and pasted the small print disclaimer that was on the ad and it says: "These vehicles are driven to make sure the major mechanical features are in good working order (i.e. engine, transmission, 4x4, rear end). We do not service or certify these vehicles nor do we pull the wheels to check things like brake wear or front end components. Buying these vehicle's thousands behind book at a wholesale value they may or may not need minor maintenence on wear items. Thank you & good luck!" Yeah, good luck because you will need it if you buy this truck! You will have no recourse because they do not certify or do any significant mechanical evaluations on their vehicles.
2004 6.0 liter(stock), 4x4 Dually King Ranch Package. Goose Neck Hitch, Bull Bar, 130 watt off road lights x 2, Vent Visors, Stainless Steel Exhaust Tip, Edge Insight Monitor, E*R Spool Kit, Dieselsite Coolant Filter Kit, GatesHeavy Duty Fleet Runner Serpentine Belt, Tires: Hankook Dynapro AT RF10 LT235/85R16 ROWL M+S. Use 16oz of Power Service fuel treatment and 1oz per gal of Blue Marble 2 stroke oil with every tank. Pullin' 30ft Travel Trailer or 20ft Deck Boat.
https://home.rr.com/bnax
Former 1996 7.3 Liter Dually XLT with conversion package , Tymar intake, Trans temp gauge, Auxiliary trans cooler.
"Give a complicated problem to a lazy man and he will always find a simple solution", words of wisdom from Uncle Smokey.
