Diesel Forum - TheDieselStop.com - View Single Post - 2004 6.0 won't start warm
Old 11-19-2008, 08:55 PM   #3 (permalink)
stuckinthemud
I'm betting you have a leak in the high pressure oil system. The pump can lerak and it leaks right back into the crank case. The rail can leak. Injectors can leak. The STC that Fordboy suggested can leak. Nothing shows on your drive way. It doesn't leak through small leaks whehn it is cold as the oil thickens.
Most of these leaks involve removing major components from the top of the engine. Are you doing it yourself or covered under warranty or something in between?
Nate
2006 F350 PSD Crew Cab, Short Box -
MODS:
I wired my radar detector into the #4 upfitter switch.
Valley Slider, full articulatioon 5er hitch.
Layton Rampage 289 - two ATVs - Box of firewood - full tank of gas...what else ya need?
stuckinthemud is offline   Reply With Quote
