Diesel Forum - TheDieselStop.com - View Single Post - Fuel dripping from under the truck - rear engine area
Old 11-20-2008, 06:37 PM   #5 (permalink)
kc2kgt
Originally Posted by bnbc View Post
I came home from work today to check out the o rings. What I discovered is that the leak seems to be coming from just above or out of the exhaust manifold where it connects to the engine block (passenger side - very rear cylinder). It collects there and drips down. Are there lines above that cylinder or do you think the fuel coming out of the cylinder into the exhaust???? Any ideas??
That's how mine dripped down from those orings. Well let me explain a little more, when I put my heads back on I did not have those plugs in them at all (guess the machine shop took them out). Made quite a mess on the driveway, but it dripped from that same spot for a while.
I don't think it would be coming out of the exhaust, my bet would still be the plugs/o-rings on the back of the heads. Do you see fuel pooling up in the valley of the engine? That's the only other possibility that I can see and then the fuel is running towards the back.
2004 F-250 King Ranch CrewCab ShortBed 6.0L
kc2kgt is offline   Reply With Quote
