Diesel Forum - TheDieselStop.com - View Single Post - Fuel dripping from under the truck - rear engine area
Old 11-21-2008, 01:07 PM   #7 (permalink)
Gofaster23
Originally Posted by bnbc View Post
I'm just hoping that I'm not having a valve problem that's allowing the fuel to get past the valve and out the exhaust - then seaping out around the manifold.
You don't, if you did the truck would run like complete s#$%. Double check the allen plugs on the back of the heads. Inspect around the secondary fuel filter housing for leaks. There are about 15 o-rings on that housing that could leak fuel. I've seen fuel leak from those areas, specifically the fuel pressure regulator cover gasket, drip down the valley, following the intake manifold lines, and down the back of the engine. Start from the top and front and work backwards.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline   Reply With Quote
