I am in the middle of installing mine, and have a question.. I got the stock waste gate off, and have worked at getting the new one in there (tough spot, and big hands, and very little visibility). I believe that the wastegate lever has turned, in all of the pics it shows the lever "pointing" towards the exhaust housing inlet, mine is "pointing" towards the turbo..
I can't turn it with my fingers, is it supposed to be easy to turn? Or do i have to put pliers on it and turn it like that? Or is it in the right spot and im just turned around?
Thanks, I will try to lightly turn it with pliers and see if that helps.
1999 F-350 CC LB 4x4. DP 80 hp econo pcm flash, TurboMaster Wastegate, KN Intake, 4" Diamond Eye Performance straight piped, gauges, BD tranny internals.. 6" Donahoe lift, 36x15.50 MT Baja ATZ, airbags, onboard compressor.
1990 Lance Camper
