OD on unless it starts hunting. If you do not have one install a transmission temp gauge. One that gives you actual degrees of temp. They are relatively easy to install and will give you a good idea of how your trans temps are doing. Gauge is most important.
2004 6.0 liter(stock), 4x4 Dually King Ranch Package. Goose Neck Hitch, Bull Bar, 130 watt off road lights x 2, Vent Visors, Stainless Steel Exhaust Tip, Edge Insight Monitor, E*R Spool Kit, Dieselsite Coolant Filter Kit, GatesHeavy Duty Fleet Runner Serpentine Belt, Tires: Hankook Dynapro AT RF10 LT235/85R16 ROWL M+S. Use 16oz of Power Service fuel treatment and 1oz per gal of Blue Marble 2 stroke oil with every tank. Pullin' 30ft Travel Trailer or 20ft Deck Boat.
https://home.rr.com/bnax
Former 1996 7.3 Liter Dually XLT with conversion package , Tymar intake, Trans temp gauge, Auxiliary trans cooler.
"Give a complicated problem to a lazy man and he will always find a simple solution", words of wisdom from Uncle Smokey.
