Originally Posted by Duramaxfarmer07
It amazed me how quick and easy this mod is to do took less than 5 minutes all you got to do is find the wire which is not hard to find and then double check its the right one then tripple check..... ect... then splice it and either solder it to the uplifter switch wire or get a wire wire connector.
Which wire did you use for SEIC?
Is is the yellow/green wire that we need to be using?
I currently have mine hooked to the BCP.
