well according to the fuel gauge, i've only gone 70 miles, and it's already used a 1/4 tank. So unless the fuel gauge is going bad, all of the repairs I just did, didn't change a thing! If it stays at this rate, i'm still at 280mi per tank and 8mpg!!!
Any other ideas?
I changed:
Air Filters
Fuel Filter
Removed the Cat
Scan Tool says all systems are within spec
To the best of my knowlage, there is a fuel pump in the fuel tank and then another fuel pump (high pressure) by the engine. Is the fuel gauge attached to the fuel pump in the tank like gasser vans, or is it something I can replace without buying a whole new pump?
