Thanks for the comments!
The injector pump is a fairly low time overhaul unit, the fuel filter is probably due replacement but is only a year old and the truck has been used sparingly on the ranch for the past year mostly due to the astronomical price of fuel (in the summer I paid over 4.85 a gallon).
The truck has no cruise control. Brake lights are good.
Anyone have a wiring diagram for this? I have the shop manual but it refers to another electrical manual. The diagram I have shows the clutch switch to have two separate single-pole switch functions; one is to contact when the clutch is about 1 inch away from full travel (the start safety function) which is also described in the troubleshooting section. The diagram doesn't really describe the second switch function or show the downstream connections for the two switches.
Tim O'Neill
'93 F-350 crew cab, 7.3 IDI, 4x4, 4:10, BFG AT
5 speed, longbox (it's always a 3 point turn)
