Diesel Forum - TheDieselStop.com - View Single Post - Tuner
Thread: Tuner
Old 12-02-2008, 09:48 AM   #5 (permalink)
Cabzbad
Cabzbad's Avatar
Just so you know.....If you have major engine problems....they will pull motor and tear it appart....and then they will know if you have a tuner...its is very obvious if you do. The way they can tell is the spray pattern on top of the piston....If I recall correctly. I should know because I had a motor pulled and I was there when the tech pulled the heads off and he showed me the increaced spray pattern. So if they really want to know they will find out.
Cabzbad is offline   Reply With Quote
