Svlandscape,
As long as the welded letters had some penetration into the base-metal, you or the police should be able to make them re-appear. One method that could be used involves polishing the surface and using a special etching compound to define the edges of the weld metal from the base metal. Some information on the process is in the following link; What etchant do I use for ... ? - AWS (welding) Code Issues FAQ - Eng-Tips
Hope it helps,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Mickey Thompson Baja ATZs, 339,000 miles, Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
