Diesel Forum - TheDieselStop.com - View Single Post - Bad Injectors
Thread: Bad Injectors
Old 12-04-2008, 12:19 PM   #4 (permalink)
dutch1918
dutch1918's Avatar
Originally Posted by Gofasterdammit View Post
Since they are all on the same bank, replace the fuel check valve for that head. The check valve is the banjo bolt that connects the fuel line to the head. After that make sure you have atleast 48 psi under WOT at the secondary fuel filter test port. You can try installing the updated fuel pressure regulator, it has a longer spring and usually jacks up the pressure a few psi. Your sig says you have a F-450, does it have the aft axle tank? If it does I would make sure all of the breather tubes are installed and pull your primary fuel filter and check for fuel tank delamination. Aft axle tanks are prone to get water in tank.
Thanks.. do you happen to have the part number for the check valve and fuel pressure regulator. Also you would think that other injectors would have failed if it was a bad fuel pressure regulator.
2009 F450 Lariet 4X4 6.4L Auto 4.30 gears Pictures
dutch1918 is offline   Reply With Quote
