Diesel Forum - TheDieselStop.com - View Single Post - Help Need Quick Advice On SB Clutch Install
Old 12-09-2008, 06:57 PM   #1 (permalink)
lomile94
I have installed a south bend Con O and have it all put back together when I realize I did not install the thin spacer ring between the flywheel bolts and the flywheel. I assumed everything was new in the kit so I did not put it on there. Everything seemed to go together fine. Do I definitely need the spacer or is it only for the stock flywheel? It will be a huge job to take it apart again. Anyone?
1994 F250, Tymar, Tuff country 2" lift
lomile94 is offline   Reply With Quote
