I have a 1999 Ford F250 with a two tank golden
fuel systems kit installed. It is an older installation in being that the main tank is the veggie tank and a 19 gallon tank is in the bed for diesel. I recently experienced a loss of power and sputtering in the veggie side so I switched back to diesel and ordered the Racor R120 filter and replaced it. Shortly after I switched back over to veggie the engine completely lost power and stalled. I haven't been able to get it to fire up since. I was told that it is probably hydro locked but I am not sure what that means. I am guessing I probably got some air in the fuel lines but am not sure how to properly bleed them now that it’s too late to prime the filter properly. When the engine does turn over lots of white smoke comes out of the exhaust, a symptom of air in the fuel lines, but I have drained the batteries four times trying to get it all out. What is the proper way to get all the air out and also to push all the veggie oil through so that I can start it off diesel since it stalled on vegg
