Diesel Forum - TheDieselStop.com - View Single Post - coolant temps
Thread: coolant temps
Old 12-17-2008, 02:28 PM   #2 (permalink)
johndeerebones
johndeerebones's Avatar
Originally Posted by drford View Post
Hi what kind of coolant temps do you have with stg 1 injectors in cold temps i cant get my truck over 160 deg at -25deg celcius
The injectors have nothing to do with it really. You need an different thermostat if you want more heat. Another helper is does your ebpv work? I gutted mine, am glad I did, but it takes 8 years of highway driving to warm it up. The stock thermostats are rated at 192 or so, that is at full flow, so in reality they start to open around 160 or 170. Dieselsite has 203* thermostats that do a better job of keeping you warm. Our cooling systems also bypass flow quite a bit of coolant when the thermostat isn't even open, unless you are pulling a load, that flow is enough to keep it cool enough to not open the thermostat for a long time. I have the same problem, just haven't ordered a thermostat, as I am trying to sell my truck, so don't wanna mess with it if I sell it. The best thing I can do is plug it in, the block heater does a bang up job of getting it up close to op temps. My cold weather starting is top notch, never had a problem starting in cold weather, esp since the sd starter, new gps and a stancor, the block heater just helps warm it up a bit, as a bonus if you leave it on defrost it puts off enough heat to thaw the windshield too.
On a side note, the only difference I have with stage ones and cold weather is holy crap does it run when its cold out, makes me think I need an intercooler. And with the straight pipe, no ebpv, and stage 1s, it smokes like a freight train sitting in the driveway when its cold out. Oh well, its a diesel, semis do the same thing when its cold out.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline   Reply With Quote
