Diesel Forum - TheDieselStop.com - View Single Post - coolant temps
Thread: coolant temps
Old 12-20-2008, 03:59 PM   #10 (permalink)
johndeerebones
johndeerebones's Avatar
Originally Posted by 444-4D View Post
Check your thermostat, you may need a new one. A good stock one will work fine. BTW the temp ratings are STO (start to open) temps. Make sure you get one the right length or it can bypass too much coolant and make the engine overheat. One other thing you might check that might make your heater work better. Does your truck have a Y at the heater hose on the front of the pass head? If it does you can block or restrict the hose returning to the radiator.
What he says, if you have the rad blocked off and its still cold replace the tstat, its gotta be stuck open.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline   Reply With Quote
