Im looking for that thread also, it was about twenty pages and i got through page 8 or something before I started the job. I have fixed the front two and failed with the rear excursion door{the plastic housing broke) Just go ahead and start tearing all the inner and outer handles and the latch out. Once you get everything undone(this is the hardest part) remove the whole housing along with the inner cable,unplug the harnesses and take out of the door. Carefully drill the two rivets out,remove the clear glue and crack it open along the seam with a screwdriver. Remove the motor, put it in a vice,bend the two tabs holding the metal to the housing outwards and mark the shell before splitting. under the plastic part there is a flat piece that you pull out with needlenose and wrap 3 or 4 times around with foil and reinstall everything. Dont stop halfway it seems for a while that this is more complicated than it turns out to be. it goes together easily and I cracked the other outer handle open to make sure I was right
