Diesel Forum - TheDieselStop.com - View Single Post - 93 non turbo, PowerStroke turbo fit??
Old 12-23-2008, 05:04 PM   #6 (permalink)
hesutton
hesutton's Avatar
My Photos: (30)
Originally Posted by 6.9 Non-Turbo Lover View Post
Your best bet would be to go with a ATS Wastegated turbo kit. The ATS Aurora 2000 Wastegated Turbo System has been the premier turbo charger system chosen by professionals for over 15 years now. In 1994 Ford installed the ATS turbo kit on every Powerstroke engine produced from the factory.
Now if you get this turbo and for 6.9 applications I recommend tweaking the fuel system by adding a 7.3 non turbos fuel injectors, fuel pump, and if your willing to go there a 7.3's cam and lifters. This will boost the power extremely and while your at it put on a boost pump. If its a 7.3 enjoy the power!
That really sounds like an ATS ad to me....and there is no real great advantage to the "Aurora." It is nothing more than a glorified name change to their original wastegated kit. Hypermax and Banks also make excellent kits and you'd be very happy with any of them. Also...........ATS NEVER supplied turbos to Ford for the PSD. They did for the IDI factory turbo.
The cam and lifters between the 7.3 and 6.9 IDI are exactly the same. There is zero difference and they have the same part number...........This is not a performance upgrade. There is NO significant difference in the IP's between the 6.9 and 7.3 IDI. Stock to stock, there is a slight increase is fuel delivery with the 7.3, but that goes out the window with a simple adjustment of the fuel screw. There also is not any significant difference in performance between their injectors..........NONE.
I'm not trying to flame anyone or start an argument, but simply clearing up any confusion or mis-information.
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
hesutton is offline   Reply With Quote
