Diesel Forum - TheDieselStop.com - View Single Post - Optima Batteries made in mexico
Old 12-31-2008, 08:39 AM   #48 (permalink)
drcampbell
My Photos: (5)
Originally Posted by TonkaThunder View Post
So how do PHCA's work? What are they?
It's just another way to test batteries.
Cold Cranking Amps (CCA) is the current at which a battery will sustain a terminal voltage of at least 1.2 Volts per cell for 30 seconds at -18 degrees Celsius.
Cranking Amps (CA) is the same test, at 0 degrees C.
Pulse Hot Cranking Amps (PHCA) is the same test, at 25 degrees C, and for five seconds instead of thirty.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline   Reply With Quote
