Recovering your serial number
Originally Posted by LandShark-47
Acid can bring a ground off serial number to the surface. Something to do with the stamp making the metal more dense or something and the acid works on the softer metal. Should be the same for a weld.
Yes the serial number can be recovered with the use of acid but it has to be done by a trailed detective or investigator. Once the number is stamped into the steel it actually lines up the molecules of the steel in that order. Even if you grind it off of the surface the acid will bring it up to the surface. However, once it brings it up to the surface it has to be photographed since it is only for a brief period and the acid will do more damage. You may want to contact this web site NICB Description
which works with the National Auto Theft Bureau for some help.
Your local or state police department should have an expert that can help you out. Good luck.
DRDON
2008 F350 Lariat CC PSD 2WD Auto. 172" Dark Blue Pearl Clearcoat Metallic/Pueblo Gold 5"Chrome CabSteps Camper Pkg. HD Alt. Tow Command Upfitter Switches, 25K Air Safe Hitch, Retrax Cover, Ride Rites, ATTA Auxiliary Tank, Trains Horns, On-Board Air, and more
2007 Ameri-Camp Summit Ridge Reserve 40' 5th wheel trailer, 3/Slides, Mor-ryde IS suspension, disc brakes, dual A/C, theatre system, solid surface counter tops, king bed, bigfoot levelers, 50 AMP service, heated tanks, 17.5 Alcoa Wheels, Michelin Tires and more
MY PICTURES:
http://good-times.webshots.com/album/558384049kmtqSi
