Old 01-04-2009, 11:39 PM   #4 (permalink)
Iqoair
Iqoair's Avatar
Originally Posted by fireguywtc View Post
does your truck have the uplifter switches in it? If you do you can wire up the high idle real easy. I did it in about 20 min and I am not very eletrically inclined. The high idle (SEIC) will bring your rpm's up to 1200 once the truck is parked with e-brake on.
Yep, it does have the uplifter switches on it. I will look into the high idle mod for sure, thanks! I'm more concerned if I have an actual problem or not, or if this is just a characteristic of the beast . Have only had the truck for about a month so far, so getting to know all the little qwirks, and I must say this forum has helped a ton.
2009 F-350 Harley Davidson CC, SB Diesel.
Iqoair is offline   Reply With Quote
