Diesel Forum - TheDieselStop.com - View Single Post - isolating vehicle batteries
Old 01-06-2009, 11:27 AM   #3 (permalink)
Cjhstang
Cjhstang's Avatar
Thanks!
i was looking at isolators. i can't figure out what amperage rating i would need on an isolator. would i need to get an isolator with the same rating as my alternator OR would i need an isolator relevant to the expected amperage draw from the two starting batteries while charging?
and of course my next question following is, what is the maximum amperage draw that a starting battery can peak when charging?
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline   Reply With Quote
