Old 01-06-2009, 08:18 PM   #4 (permalink)
chuckster57
chuckster57's Avatar
The difference in OBD I and OBD II connectors is the OBD II is in the passenger compartment and is a 16 pin trapazoid and OBD I is a 6 pin with a separate "jumper" wire and is located in the engine compartment. Your DLC should be under the edge of the dash on the right side of the steering wheel.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
chuckster57 is offline   Reply With Quote
