Can I weld it ?
Sure you can. Seal it as quick as you can to keep moisture out. Don't weld it on the truck . Block the openings any way you can while it's off. Get a can of 134A and charge it partially until spring then dump that charge out, or have it pro-charged in the spring. Pull the plug on the A/C compressor, it will want to run when the defrosters are on .
My .04 cents worth,adjusted for inflation.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
