Diesel Forum - TheDieselStop.com - View Single Post - WMO filtering is this enough?
Old 01-08-2009, 09:25 PM   #1 (permalink)
rockets10510
Send a message via AIM to rockets10510
the set up i have filters the oil down to 2 micros. there are 3 different filters. the first filter is a 25 micron house water filter, the second is a 5 micron house water filter and the third is a wix 2 micron fuel filter. is this enough? another question would a cenerfuuge be a good investment as far as filtering wmo for fuel use? or is filtering it down to 2 microns good enough?
thanks anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline   Reply With Quote
