Diesel Forum - TheDieselStop.com - View Single Post - Not enough heat at idle when cold
Old 01-09-2009, 09:58 AM   #6 (permalink)
mcbigbuck
thermostat
Originally Posted by Iqoair View Post
When it's cold (-10c and below, especially -20+) I have little heat at idle. If it's -20c or below it's no heat at idle. Today ( -9c ) it was acceptable, however not great. When the RPM's are over 1000 it seems to pump it out ok. The engine coolant temp sits a little below the middle mark after it warms up (10-15 mins).
4wd works fine, the heater control vent options work fine. No coolant leaks (that I'm aware of), and the coolant level is at "min" when cold and hasn't budged. Lots of power and no other symptoms. 80,000 kms on the truck, 2006 F-350 6.0.
Suggestions?
Mine did same thing a month ago here in montana and it was a bad thermostat. Sounds funky but it was the fix. Temp gauge indicated warm also which confused me, but Ford fixed it. Good luck
mcbigbuck is offline   Reply With Quote
