Diesel Forum - TheDieselStop.com - View Single Post - Not enough heat at idle when cold
Old 01-09-2009, 10:05 AM   #7 (permalink)
w_huisman
w_huisman's Avatar
Originally Posted by mcbigbuck View Post
Mine did same thing a month ago here in montana and it was a bad thermostat. Sounds funky but it was the fix. Temp gauge indicated warm also which confused me, but Ford fixed it. Good luck
The only actual oem "gauges" in my truck are the speedometer and the tach. All the others are (nearly worthless) idiot switches that just go to the middle when their sensor senses a specific setting.
You may be able to get an actual coolant temp reading from the odometer display using the methods described in the owner's manual. If your water temps drop significantly when you're at idle, that would be an indication of a stuck open thermostat.
2006 F250 6.0 Lariat
cc sb 4x4 auto 67k, coolant filter, analog FP gauge + Edge Insight w/ EGT. VXCF9H7 strategy
All else stock.
w_huisman is offline   Reply With Quote
