Diesel Forum - TheDieselStop.com - View Single Post - Not enough heat at idle when cold
Old 01-10-2009, 12:14 AM   #10 (permalink)
Iqoair
Iqoair's Avatar
Originally Posted by drford View Post
this is a problem up here i have 4 truck doing this at my shop the local ford dealer here has 38 plus trucks with the same issue and no fix for it in testing and working very closely with the dealership we have discovered the following the coolant flow is lost to the heater core ( how was this test done we disconnected the heater core supply hose and ran it to the degas bottle while at idle no or extremely little flow through the line idle truck up all ok ) we have replaced the following on one truck with NO change in results 4 thermostats , water pump , heater core , coolant flush , head gaskets , egr cooler , after all this back to ford to talk to them we were on with tech support they claim this is a normal condition for the 6.0l and no fix is available ( i call BS they are just trying to wash their hands of the 6.0l issue . WHY ALL OF A SUDDEN ? THERE WERE NO COMPLAINTS LAST WINTER AND NOW THERE IS ???)
I'm going to try the cardboard behind the front grill trick and see what happens. I'll report back to you guys. Heat is nice now that it's 2c outside
2009 F-350 Harley Davidson CC, SB Diesel.
Iqoair is offline   Reply With Quote
