Diesel Forum - TheDieselStop.com - View Single Post - Isspro pyrometer question
Old 01-21-2009, 01:13 PM   #5 (permalink)
MJPliska
Originally Posted by Justin C. View Post
My existing gauge has two wires going to it which I assumed were power and ground, but may not be. The gauge is lighted and dims with the interior lights. I replaced my old 30 psi boost gauge with an EV 60 psi gauge a few months ago and didn't have to do anything to get it working.
The 2 wires you have are likely ground and dimmer, just for running the lights. You can use the same ground, but in addition to the dimmer wire you will need a keyed-ignition source (a wire which supplies battery voltage when the key is on but turns off with the key).
My boost gauge has a red pointer so I would prefer to stick with that, but I didn't see pyrometers available with the red pointer and colored numbers like my existing pyrometer has. Is that available in the EV2?
Yup, the R17021 is red pointer with color coding for pre-turbo limits.
Also - can the bulb be changed in the new pyrometer? I have converted mine to Green LED's to match my dash, and just want to make sure I
can stick with that.
Sorry for all the questions but thanks for all your help.
Justin
The LEDs are built in and cannot be changed, but they are already green backlit and a perfect match for your dash lighting. I know the color is perfect, we used my OBS truck for the match!
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 288k miles (Ford rebuilt E4OD at 226k)
10 ISSPRO Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps & Tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
2000 Jetta TDI - Kerma reflash, Der Chimera Stage II Clutch
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
MJPliska is offline   Reply With Quote
