Diesel Forum - TheDieselStop.com - View Single Post - How to replace early ICP - with pictures
Old 01-21-2009, 06:16 PM   #29 (permalink)
wingnut1961
Originally Posted by andrewbalser View Post
This is a great post! I've been seeing more ICP related posts on here as of late. I guess I'm gonna have to add it to my pre-warranty termination checklist. I have either until June 4, 2009, or near 12k left on my deductible warranty. I'm sure I won't make it to June 4th!. Mine is a huntsville 5/21/03 engine. So--- this thing is on the drivers side of the engine block? or is it mounted ON the valve cover. I gathered that it's somewhat under the FICM, or behind it or something?
OK.. I see now. I was having trouble figuring out at first, just where the cameraman was standing! =)
5/03 = driver's (left) side, top/back of the engine, behind a heat shield. If a 4WD, remove the front drive shaft for better access. You also need to loosen the trans dip stick tube to reach heat shield bolts on right side of engine.
2003 F250 SD XLT Crewcab 6.0L 4WD Auto 6/03 build date
wingnut1961 is offline   Reply With Quote
