Brake Caliper Slide Shims
I've noticed that since I replaced my front brake calipers with OEM Ford/Motorcraft remanufactured units a few years ago, I've been getting a clunk noise from the passenger side of the truck when the suspension cycles. I've examined that side of the truck and determined that there's a fair amount of slop (~1/16") between the caliper slides and caliper mounting bracket slides, causing the clunk. So, I'm guessing Ford's caliper reman contractor didn't check the dimensional specs of the caliper they remanned, and I ended up with the result.
I've heard that there's shims available in the aftermarket to correct this situation, but I haven't had any luck finding them. So, if anyone has any recommended part numbers or suppliers for the shims, please let me know.
Keep in mind that my truck is a 94, so its calipers use the older split steel and rubber slide pins; not the bolt, sleve, and boot type on the 95-up PSDs.
Thanks,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Mickey Thompson Baja ATZs, 339,000 miles, Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
