A different cause
I to have this problem with the dar ajar and the dome light staying on. I have found my source of the problem to be in the back door "Extended Cab". At the bottem of the door it has a i guess you would call it a tack (factoy) weld. When the back door closes it latches to the cab then when the front door shuts it latches to the back door. I guess over the years of the front door pulling on the back door it has pulled this weld loose. So when I shut the front door it doesnt close fully. I can push on the doors at the seem where they close and the light goes out. I have read the post and not seen anyone mention that yet. Not sure if this would be the cause of anyone elses door problem but I hope this helps as well.
 *2001 F250 PSD 6 speed manual 4x4
*4" Skyjacker lift, Skyjacker Shocks, Dual Skyjacker steering Stabilizers, 315/75R16 Toyo Open Country M/T tires, 16x10 Mickey Thompson Classic II wheels, Edge Evolution II, 4" MBRP turbo back exhaust (Aluminized), S&B Cold Air Intake, polyurethane cab mount bushings, bellowed up pipes.
