Diesel Forum - TheDieselStop.com - View Single Post - Fog Lights/High Beam?
Old 01-27-2009, 09:12 PM   #5 (permalink)
Stymie
Stymie's Avatar
on the 2004 F-150 i had, all you had to do was pop the switch out. On the back of the switch you took the wife for the fog lights, and tapped the wire for the running lights into it. this turns your fog lights on, whenever your running lights are on. It does this by sending voltage to the relay for the fog lights. ITs pretty simple to do. here is a pic of my lightning's switch.
you can see i just took a scotch connector and jumpered the wires
if anyone has the schematics for the switch it would be easy.
another thing to do is pull the switch and measure voltage on the wires in different switch settings
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline   Reply With Quote
