Diesel Forum - TheDieselStop.com - View Single Post - Bio-Diesel use in a 7.3 issues?
Old 01-29-2009, 11:52 AM   #9 (permalink)
Spencnaz
Spencnaz's Avatar
My Photos: (14)
A couple of issues with the 7.3 you need to be mindful of.
1. Keep the oil clean. Change that oil every 3-5k miles religiously. The injection system uses oil pressure to activate the injectors themselves. Dirty oil will either hamper or clog the injector system.
2. The CPS (crankcase position sensor), these can go out but are very easy to replace. Many chain auto parts stores will have them in stock.
3. If you have a '96 or earlier, be mindful that the revised and increased the size of the glow plug timer/controller that sits on top of the engine. The early models had this little wimpy looking thing but was later replaced by a much more substantial glowplug relay. If you can, upgrade to the newer relay.
4. Injector pressure: since these engines run a direct injection process, the injection pressure is going to be much higher than an indirect injection process. Be sure that the biodiesel or WVO you plan on using is very very clean, even a speck of trash can ruin an injector.
Hope these little tips help. Personally, I like the 7.3 but I've never been a fan of engines with computers on them, I like to keep things simple.
If my 6.9 gives up on me, I may consider getting a 97-99 Powerstroke.
Spencnaz is offline   Reply With Quote
