Diesel Forum - TheDieselStop.com - View Single Post - Bio-Diesel use in a 7.3 issues?
Old 02-01-2009, 12:07 AM   #10 (permalink)
350 long rod
My Photos: (17)
Originally Posted by unimogr View Post
My dealer in Munich, Schussler told me they see problems w/ trucks running Bio. I assume it's home brew vs. store bought (is there a difference?) but I run B-20 in the summer and so far it runs great and the fuel tank is shinny clean inside. I need to talk to the guys at Boston Fuel Injection to see if the Bosch model W pump would have compatibillity issues.
Should be no difference as long as both were made and washed correctly.The only difference would be gel point due to feed stock difference.I have been running home brew in my 1999 E300TD for 30k plus and have not clogged a filter yet and only have changed it once.The only issues with the pump would be with the seals I would think.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline   Reply With Quote
