About the only way to find out if the heads are cracked would be to magnaflux them. Few if any dealers do this.
You said they found no failures when they pulled the heads or with the EGR cooler. Presuming they are correct, my next question is, did they check the oil cooler? The TSB on puking says they are to do so. If they did not, then there is still one part of the diagnosis that has not been done.
One last question.... Did they try replacing the cap? There have been a few batchs of bad caps out there.......
 2003 Toreador Red/ Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
pics
#43
SLAPS President and Webmaster
