Diesel Forum - TheDieselStop.com - View Single Post - Bought a used '04 and Need Your Brains
Old 02-13-2009, 02:43 AM   #6 (permalink)
B-rad
I would keep up on cleaning your EGR valve, I been seeing a lot of them plugged up and causing problems. If your not running it too much I would pull the EGR valve and clean it out. Make sure you clean it with the valve part (canister) up so you don't screw up the valve.
1993 Bronco, 351, 5 speed conversion, 6 inch lift 35's. In process of one ton swap.
1996 F-150, I6, 2wd, regular cab, shortbed, reliable as hell.
2003 Harley Davidson sportster, 1200, 100th year edition
2007 Yamaha YFZ450, to go where the Bronco cant
2002 Ford F-350 7.3, CC, LB, auto everything, 315/75/16 with level kit only, Torador Red, BIG RED
B-rad is offline   Reply With Quote
