Diesel Forum - TheDieselStop.com - View Single Post - 1990 e350 overdrive light blinking
Old 02-15-2009, 12:39 AM   #2 (permalink)
chuckster57
chuckster57's Avatar
E4OD is computer controlled and if the OD light is flashing then it means there is probably a trouble code set. Your truck is OBD I and if you have an OBD I scanner it will give you the codes. If you don't have a scanner you can get the codes with an ANALOG volt meter. Just follow the directions in the link:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now   Reply With Quote
